- Thu Jan 28, 2016 9:55 pm
#54743
Brief summary:
Classic Bullet Engine: alloy con-rod with steel big-end eye pressed in, RE "floating bush" big end bearing, crank pin fitted with retaining nuts. Oscillating plunger oil pumps. Smoother timing cover. Ignition by contact breaker assembly or by magneto behind the cylinder. Thicker stem cam followers. Cast iron cylinder barrel (alloy for competition of after-market modification). Older-style cylinder head with hemi-spherical combustion chamber, 2nd 14mm thread for decompressor valve. Rocker spindles held in blocks boltd to the cylinder head.
AVL Engine: Japanese style short steel con-rod with needle roller big end on plain crank pin running directly in the con-rod. Crank pin is press-fit in flywheels, no retaining nuts. Gear type oil pumps with lumpy timing cover. Crankshaft-mounted ignition trigger, no contact beaker assembly or magneto fitted. Thin stem cam followers with revised cam profile. Alloy cylinder barrel, shorter than the cast iron version. Redesigned head with pent roof combustion chamber, rocker spindles mount directly in the head casting. No decompressor valve in the head, valve lifter fitted in tappet chamber.
