[center]
YES!
I have had three RE's and all of them were given Lithium-ion batteries. The promising points were,
If bike falls over, no acid to leak out and rot things.
Higher power delivery
Can be fitted anyway up
much smaller battery for same power output
Only a fraction of the weight of a wet battery
Less maintenance charging needed
when finally dies, the slats inside make good plant compost apparently.
In practice,
Don't get hot
don't go bang
don't leak acid
seems almost fully charged after being away for 2 months or so.
Nasty
nasty big lumbering historical acid bottle
On it's side, in the bottom there, leaving room for a first aid kit on top! YAY!
My Bikes don't want to making no more acid trips... we're all lithium now!
So my EFI with leccy start that I hardly ever used worked great, Tornado my iron bullet runs well and Kevin, my Meteor Minor seems to run well on one so I have absolutely no complains other than they cost rather a bit,
but, you fit and (almost) forget. Recommended.
