- Mon Jan 11, 2016 10:49 pm
#5848
For many years I have set ignition timing by ear for fastest/smoothest running at idle, then left it to the centrifugal advance to deal with the rest. This seemed to result in being somewhere near quoted static advance as confirmed with plunger down the plug hole, so I accepted it as okay.
However, recently I have cobbled up a (temporary?)simple lever to alter timing whilst actually riding in order to determine an "optimum" setting under road conditions.
My "optimum" setting gives much smoother running both under acceleration and steady running with much less mechanical noise and also a more subdued exhaust tone in mid range than I have ever had before. It certainly gives the impression of being kinder on my bottom end bearings with reduction in harsh clatter!
"Optimum" appears to be a more retarded setting than I used previously, but whilst giving an extremely consistent tickover any temporary advance does lead to a significant increase in idle revs which gives me some doubts about it.
The centrifugal mechanism is working okay, so I am wondering if I have been running way too much advance for ages - or do the standard advance curve and stops just not suit the engine very well?
