- Mon Nov 16, 2015 12:15 pm
#5703
I've just bought a 1999 500 Bullet, having ridden Enfields in India and Nepal and got rather addicted. It starts easily and ticks over with a bit of popping, but as soon as I touch the throttle from fully closed it dies. it's got a Mikcarb with S&B conical filter, 27.5 pilot jet and 130 main jet, and Boyer Bransden Micro 4 ignition. The exhaust system is standard. I've taken the carb off and the pilot jet is rather clogged up, but apart from that it all looks clean inside. The air adjuster screw is fully in and the throttle screw is 4 1/2 turns out. The engine (and presumably the carb too) has apparently only done about 2,000 kms. I'm going to put in a new pilot jet, gaskets and o-rings, and hopefully it'll tick over like a waiting bomb. Is there anything else I should investigate? Thanks for any suggestions. Mark.
