- Wed Nov 11, 2015 11:31 am
#52209
Ah, but you ain't got the book yet.
Yes, do run it in!
I got additional advice from dealer.
0-500km (300 miles) to first service) keep below 35-40mph and under half throttle, this is a slow pootle, put-put-put, boring but do it. At first service the dealership replaced foc mudguard bolts that had fallen off and one on rear mudguard stay that had sheared. Loctite! Oil and filters changed out were clean. First service is not just oil and filters but full inspection - check entire bike over for defects and fix. They gave me the C-spanner for the rear shocks then. Get a bottle of Loctite and keep an eye on the nuts and bolts. Most of the screws are small diameter, they do not need to be stripped or snapped off by a gorilla.
500-1000km (600miles) keep below 45-50mph, avoid full throttle.
You will feel the bike loosening up. Above 1000km "avoid use of full throttle". I've got close to 1000 miles on the clock and am still riding 'gently'
Some daft advice in the book of words such as, "Do not exceed 70mph riding solo" (55mph with pillion). If you can find a good bit of road the bike will easily go over 70 and is rock steady, apart from the wind buffeting due to upright position.
New tyres need running in too (!), they get more grippy after a couple of days.
