Page 1 of 3
Crankcase breather
Posted: Wed Nov 04, 2015 7:30 pm
by Martman
Hi, I have a 1946 model co. My question is , would it be worth putting a rubber breather pipe, which seals, on the end of the copper crankcase breather pipe.
I understand with the pipe sealing, maintains a vacuum in the crankcase.
What are the thoughts? Martman
Crankcase breather
Posted: Thu Nov 05, 2015 12:43 am
by WDCO42
Hello Martman,
That's what I did on my CO years ago. For me there are two problems with the original breather : the 2 small confetti that are supposed to seal it when the piston goes to TDC, and the poor diameter of the tube. So I made a new one, with a tube accepting the Bullet plastic breather pipe, but I kept the original "S" design of the pipe, and it still oils the rear chain.
Hope it wil help you
Claude
Crankcase breather
Posted: Thu Nov 05, 2015 8:10 am
by Martman
Hi Claude, Good idea, I think I will do the same. Any tips on sealing the large rubber band on the chain case cover.
Crankcase breather
Posted: Sat Nov 07, 2015 8:28 pm
by WDCO42
Hello Martman, The problem is that when you fit your rubber band, and press the outer chain case cover , the inner tends to flex, in the "banana" way.
I fit first the rubber band, sealed with silicone, to the rear chain case. then wait it is glued. And when I fit the outer one, I smear a bit of sealing paste on the outer side of the rubber band, to have some kind of lubrication that will help the fitting. In fact, I realised that the problem wasn't that the case was oil tight, but that the chain got some lubrication. So, I fitted an auxiliary small can with a tap(on the battery strap), connected to a drip feed inside the chain case, the kind you see on Norton Manx. So, when I ride, I regulary open the tap, and have my 6 oil drips per minute on the primary chain, and am sure it is correctly lubricated. The sealing problem is then avoided.
I don't know how to fit pictures on this forum, but if you want, give me your email address, and I'll send you some photos.
Hope it will help you
Claude
Crankcase breather
Posted: Sat Nov 07, 2015 11:05 pm
Claude,
to get a picture up on here you need to do the following;
< b r > (WITHOUT the spaces) before and after the picture as well as at the end of every paragraph you can format your message.
Crankcase breather
Posted: Sat Nov 07, 2015 11:07 pm
Sorry, item 1 was to open an account with a photo hosting website, eg Imagesia. For some reason this forum software chose to moit my first point! It is rubbish compared to other forum software. A
Crankcase breather
Posted: Sat Nov 07, 2015 11:08 pm
So, is my typing, that should read omit, not moit. I'm going now...
Crankcase breather
Posted: Sun Nov 08, 2015 1:56 am
by WDCO42
Crankcase breather
Posted: Sun Nov 08, 2015 2:07 am
by WDCO42
Well, I certainly missed something... But anyway you can go to the photo.
There will you see the oil can with the tap, bolted to the battery strap.
http://imagesia.com/dsc-0542_12ye8
Crankcase breather
Posted: Sun Nov 08, 2015 2:17 am
by WDCO42
Still not very efficient...
Here is, at least, the link for a photo where you see an other mod I made : a kind of relay for the valve lifter. It is rather hard to fit the valve lifter cable in the cylinder, so the idea was to have a permanent one (hidden there by the cross), connected to a pivoting cross, that transmits the movement via an other cable, much easier disconectable. It works fine, and is easier settable too. http://imagesia.com/dsc-0542_12ye8 Hope it will give you some ideas. Claude
