cutting out
Posted: Sun Oct 11, 2015 2:39 pm
by spro
Hi i have a problem with my 500cc bullet electra,starts ok on the electric starter run fine untill the lights are switched on then it misfires and cuts out.has had a new battery fitted and when tested the voltage at the battery is ok at about 13.4 volts. Has anyone had the same problem or any ideas
Thanks
cutting out
Posted: Sun Oct 11, 2015 3:36 pm
by Les
As a first step I would suggest putting your meter across the battery with the engine running and then switch on the lights then check the voltage
cutting out
Posted: Sun Oct 11, 2015 4:01 pm
by spro
Hi Les thanks for the reply have done that and get a reading between 12.9 volts and 13.5 volt
cutting out
Posted: Sun Oct 11, 2015 4:20 pm
by Frank
I had the same problem on mine, caused by a faulty headlamp bulb. It lit OK but a bad earth connection inside the bulb caused the problems. It could just as easily be in another part of the lighting circuit, the pilot light wiring is shockingly flimsy and not fit for purpose. It might be a case of disconnecting each bulb in turn to see if the fault disappears and go from there. A bad earth causes very strange problems.
cutting out
Posted: Sun Oct 11, 2015 6:35 pm
by Robin
Hi Spro. I think I had a similar problem on my Electra X many years ago. And ended up having to ride 20 miles home, in the dark with no lights. It turned out to be a malfunctioning reg/rec, if I remember correctly. Replaced the 'Swiss' unit with a power box and never had these weird kinds of electrical problems again.
cutting out
Posted: Sun Oct 11, 2015 8:56 pm
by sa(lincs)
Hi had same problem, wire chaffed thro to rear light,disconnect cable to rear lights and check again then do front lights ,take bulbs out one by one,you have a short someware
cutting out
Posted: Sun Oct 11, 2015 9:48 pm
by Scalyback
[center]
Tornado had one of these. Someone had moved it to the toolbox so that it overheated when I started using the headlamp.
cutting out
Posted: Tue Oct 13, 2015 4:58 am
by spro
Thanks for the everyone for the helpful replys will give it a go at the weekend if i get a chance
Cheers
cutting out
Posted: Tue Oct 13, 2015 6:50 am
by Lee B
My tuppence - Exactly the same problem last year on my Electra. The wire in the Headlamp unit had chaffed and was earthing. My local RE specialst advised this was a common issue! Good luck and post the cause/remedy of your issue!
