350 Bullet Intermittent Timing Side Noise
Posted: Wed Sep 09, 2015 11:27 am
Hi all
I've got a mystery intermittent clanking noise coming from the engine of my '94 Indian Bullet. I stripped and worked on the bike over the winter, and the engine's been decoked and had new Samrat rockers, head gasket, oil filter, iridium plug and ignition advance springs from our hosts here. The engine was running well before the rebuild, though the intake rocker was a little loose and noisy - hence the new Samrats.
The noise is an alloy kind of clank/click, and it's intermittent, occurring once every 5-10 seconds when the engine idles. It's hard to tell but it seems to be coming from the timing side. It wasn't present when I first started the bike after the rebuild, but started up soon after. It originally seemed to disappear at higher revs, though I'm not sure this is the case any more. It could also be my imagination but it seems as though it's getting louder and more frequent.
I've checked all the usual suspects and can confirm it's not the head steady, the primary chain tensioner, the alternator, or any other obvious nuts/bolts on the crankcases. I also don't think it's the tappets - I've checked tappet clearances, correctly torqued rocker blocks etc. It also seems too irregular a noise to be anything in the valve chain. The bike also starts first kick and is utterly lovely in every other respect - pulling strongly and generally behaving itself. Idle is smooth and doesn't miss a beat - there's just this damned clank which puts my teeth on edge every 5 seconds.
I've been reading old threads on here, and it seems as though it's a similar issue to the one Simon had in the 'Clank is back' thread. I could be being stupid, but reading that thread it seemed to stop short before a solution was found - does anyone know what the cause of Simon's mystery clanking noise was?
I'll get the timing cover off over the weekend and let you all know the condition of the oil pump parts - it's occurred to me that the spindle might be slipping a tooth every now and then.
Many thanks in advance for any help folks - all the very best - Alasdair
