By Skylon
#5475
Hi
May 2014 i bought a new petrol tap (141541 1 PETROL TAP WITH FILTER/RESERVE, 1/4 gas) It fitted well and seemed to be ok. But since then i had problems, in the beginning, when i ran for full throtle, it could happen that the engine died, i did not know if it was an electric or petrol problem but after turning the petrol tap to reserve it ran again. later on the engine also could die on reserve. but then run again if switched to normal (in all cases there was plenty of petrol in the tank) I also blew out the system backwards and the petrol ran ok. On a longer trip this weekend it happened several times a day and also on the Great belt bridge which was not fun. Home I took the tank of and drained it, took out the petrol tap. the filter was not blocked and one could blow through the tap. Then i dismantled the tap and I noticed that the rubber disc with two big and two smaller holes was mounted with the big holes ower the locking tap and the small holes by the groove. There was some rubber crates left in the smaller holes. I believe that the rubber slowly has compressed and closed the holes. but after mowing it it has opened again until after some time it has closed again. I have now mounted the rubber disc with the small holes on the locking pins and mounted the tap again. Hopefully the problem is now solved.
By Scalyback
#50698
Well I bought a 36583 with reserve. When off it is fine. the only problem seems to be that it leaks fuel from the sliding on off thing when in the on position. I am not totally sure and willinvestigate further, but it seems to tbe the slider at the moment.
It's the right patten, just need more time to see if tap faulty or if It is a joint.
I think your tap has cork inserts, Scaly. Sourcing replacement material for carving your own inserts should not be a problem in France! A.
By Scalyback
#50724
I only bought the thing a couple of weeks ago!
By eddie.b
#50730
Distant memory tells me that we used to remove cork bits like that and give them a good boil up in an old pan of water swelled he cork up and gave it a new lease of life, can even remember doing clutch plates when I couldn't afford new plates and needed to get to work. Might be worth a try
By papasmurf
#50733
Coconut oil works well on any petrol related gaskets. (It is cheap as well.) It is a grease at room temperature and liquid at blood heat.
