Refurbished distributor
Posted: Sat Aug 29, 2015 2:17 pm
Hi all,
Rusty (my trusty rusty 350 Superstar) had a sloppy distributor - ok I know it's not a real distributor, more of a points housing, but you know the part I mean...
I knocked out the two steel bushes (steel??!!) and confirmed they were cream crackered. Problem was that not only were the insides of the bushes worn, but the spindle where it bore on the bushes had worn a few thou undersize. I reasoned:
1. Steel on steel isn't a good idea
2. Putting new unworn bushes in wouldn't cure the 'slop'
So off to my mate Peter in the village. He has lathes, mills etc in his garage AND knows how to use 'em! He made up and installed new fozzy-bronze bushes, line-reamed them and skimmed a few though off the shaft where it hadn't worn (thus allowing the shaft to slide in).
What a great job! No play at all and will probably last better than the steel bushes too!
I know the newer ones have proper bearings, but I want to keep as many of Rusty's parts original and you can't fit ball-bearings in the old-style casting.
Has anyone else done a similar job?
Stephen
Stephen
