By Rob S
#5376
Hi everyone,Does anyone know the cykinder head torque settings for a 1962 Crusader Sports, I can't find anything in my workshop manual or on line, many thanks.
Rob
#50009
22-23/ft lbs. Make sure the stud holes are clear by running a clearance drill through first to remove excess alloy. Also fit our Hosts hardened steel washers to prevent crushing in future. These are in the Bullet catalogue, you will have to phone them to get a set as they will be slightly different from the Bullet set. By the way, there is an information group just for the Crusaders at https://groups.yahoo.com/neo/groups/Cru ... group/info where you will find a lot of friendly help and data in the Files section.
#50017
The quoted figure is with the threads dry. If they have oil/loctite on the figure will be a lot lower.
By Scalyback
#50018
WAAAAAAAHHH!
Every other bike had got it's own group or forum. I don't suppose there is a Meteor Minor one?
By Rob S
#50031
many thanks for your replies, I have ordered the washers and a few other bits and pieces I was needing.
Cheers
Rob
