- Mon Jul 27, 2015 3:22 pm
#5363
Hi need some information I have a crankshaft that is fitted with a alpha big end assy in trying to check out the pressure relief valve to see if would work I found it had no movement in it so I had it stripped down to see what wrong and found that the relief valve had been removed and a blanking plug fitted I bought the parts fitted them so then used a oilcan to check on the flow to the big end the oil just came out of the relief valve so my question is do I need to use the relief valve or can I just use the blanking plug at least this way the oil got to the big end assy sorry its a bit long winded but its the only way to explain
Andy
Andy
