- Fri Jul 10, 2015 5:08 pm
#5296
I have a strange charging problem on this Bike. It no longer has the Selenium rectifier which has been replaced with an electronic one. The Alternator voltage varies up to about 20 volts and the DC output from the rectifier about is about 7.5 volts which to my mind is adequate. As soon as I connect the DC wires from the rectifier into the wiring harness the voltage at the Battery decreases to about 5.5 volts and reflects no further charge. If I connect the same wires from the rectifier to a free standing battery I get a good positive charge of 7.5volts. The Bike is positive earth and I have double checked the entire wiring system but have been unable to establish where the problem is. I have even thought of changing the wiring to negative earth which to my mind is a lot less complicated and more understandable. I have also swopped the batteries around in case it was faulty but no difference. Any suggestions would really be appreciated
