Page 1 of 4
sudden clutch cable slack
Posted: Tue Jun 23, 2015 7:41 am
by papasmurf
Electra X, sudden clutch cable slack, clutch still operating OK, any idea of impending doom or similar please?
Posted: Tue Jun 23, 2015 8:02 am
by Davie Hall
It could be the cable starting to fray. Have a look where the cable enters the gearbox and see if the adjuster has screwed itself in
Posted: Tue Jun 23, 2015 8:10 am
by papasmurf
Clutch is still as light as a feather,(frayed cables in my experience make the clutch action tight) nothing was loose anywhere either end of the cable.
Bike is in for a service shortly I will get the mechanic to check the clutch whilst the cover is off.
Posted: Tue Jun 23, 2015 8:12 am
by PO51UHD
Mine on my ElecraX went very suddenly, and it was the cable, so I agree with Davie's recommendation. Also check you have the modified clutch cable and actuating (scissors-type) mechanism which is designed to prevent this happening - the mod includes a curved tubular cable entry point on the gearbox.
Stephen
Posted: Tue Jun 23, 2015 8:59 am
by papasmurf
Modified clutch cable? I can't find that listed.
Posted: Tue Jun 23, 2015 10:43 am
by Adam
Is it possible that the last time the cable was disturbed (for whatever reason) that one end of the outer sleeve ended up resting on the edge of the cup in which it should sit and has just decided to jump into the cup? Or that something had gotten trapped under the end of the cable outer and just decided to crumble? Stranger things have happened. I would be tempted to adjust out the slack and ‘suck it and see’. Adam
Posted: Tue Jun 23, 2015 10:56 am
by papasmurf
Adam, I intended to "double up" on Bowden cables on the bike anyway I have just ordered a set of cables from our hosts plus the clutch pad with bearing.
Having had a chat with an "expert" the clutch cable stretching before it fails is common. The replacement on the way is an English made cable.
Posted: Tue Jun 23, 2015 3:51 pm
by Gwilly
The cables do snap where they adjoin the actuator lever due to twisting and poor angle..
There have been more than a few where the lever gives out on the ball and ramp mechanism as pictured courtesy of Mr Snidal..
Our host do a modified version with swivel attachment for the cable. hopefully to lessen the problem.
See top assembly.
Posted: Tue Jun 23, 2015 3:59 pm
by papasmurf
I can't find that modified swivel anywhere in the catalogue.
Posted: Tue Jun 23, 2015 6:36 pm
by Frank
Part 90146A. New gearbox cover, clutch cable and actuating arm.
