Kick starting efi's...
Posted: Mon Jun 22, 2015 9:37 pm
by Bazza
Ok so I have only done around 100 miles but I have not got the knack for the kick start.
Its a new efi - I kno wthe theory use the kick starter to get past TDC and then go for it.
clutch in? bit of throttle? Any tips please...
Posted: Mon Jun 22, 2015 10:17 pm
by Scalyback
when cold, operate the choke/enriching/whatever lever on the left handlebar, usually no throttle, kick once (Maybe twice)
Wait a few seconds, release enriching lever.
If it works on your EFI, then stick to it!
Posted: Mon Jun 22, 2015 10:58 pm
by Leon Novello
Make sure you practice until you get it right, otherwise you will become, in your old age, one of us who walk around mumbling,"start ya bastard."
Posted: Tue Jun 23, 2015 8:03 am
by Nettshubby
By "clutch in" i presume (hope!) you mean lever not pulled in. If you pull lever in obviously you disconnect the the drive from the engine.
Posted: Tue Jun 23, 2015 4:03 pm
by Jim
I think these little divils are a little light in the flywheel department. With my 500cc heffy I've always found it best to bring it up onto compression and then welly it rather than easing it over TDC. It usually starts first time.
I only need to use the enrichment jet during the coldest of winter months.
Posted: Tue Jun 23, 2015 4:22 pm
by Les
I put mine up to compression return the kick start to the top and give a good heavy kick it takes some effort to be sucessful
Posted: Wed Jun 24, 2015 10:11 am
by papasmurf
Posted: Wed Jun 24, 2015 2:39 pm
by Les
D you have the helmet to go with the boots
Posted: Wed Jun 24, 2015 2:43 pm
by papasmurf
No Les but I know a man who does, plus the complete diving suit and compressor. He still uses it from time to time.
