By monkey hanger
#5185
Hi. Electric start on my 2005 Electra X has decided it does not want to play any longer. Press the starter button and nothing happens apart from seeing the AMPS needle drop. Thank goodness its got a kick start. All other electrics work ok, could problem be with the starter motor??any suggestions as to what the problem could be most welcome.
#48482
First thing, is the solenoid clicking?
By monkey hanger
#48487
Hi Pete thanks for the reply.
Just checked and no not a click to be heard from the solenoid so am guessing that is the problem.
By tedmunds
#48488
Check the connections on the solenoid, and starter. Check for corrosion, clean them up and re-tighten. Mine had corroded when I first got my bike and it made a big difference after re-doing the connections. I also got rid of the old glass fuses and replaced with spade type fuses again a big improvement was noticed.
By Paul M H
#48489
With the Amp metre going well over it sounds like it may just be the battery has not got the guts too turn the starter motor. Try it with a good battery or charge it up fully first then try again. Do the side lights dim when pushing the starter button.
Checking/cleaning connections is good advice, but from experience I'm with Paul on this - a tired battery will definitely not want play with the E/S, even though the bike might still start and run when kick-started. How old is the battery on your bike?
Or look at it another way, your battery is trying to save your sprag clutch...
By monkey hanger
#48494
The battery is a new Gel one from our host and is fully charged. Perhaps mislead you on the amp meter as needle only goes over into negative a small way when pressing starter button. Looking in our hosts catalogue I cannot find any solenoids under electrical etc. Do they refer to them by another name. All connections look in good clean condition and secure.
By PO51UHD
#48496
My ElecraX did the same thing, and from what's been said I would replace the solenoid for starters (sorry, couldn't resist that one!) - mine had given up the ghost. Have a look on Fleabay - I bought a Japanese one which looked identical to the OEM one and it was dirt cheap - solved the problem too!
Good luck
Stephen
By Davie Hall
#48499
AN easy way to check your solenoid is to short an old screw driver across the large terminals and see if the starter operates. My Electra X had the same the same problem and I changed it with a cheap Chinese one and it works fine.
#48502
Go to the "parts books on line" on the left of this page. Select your machine. Solenoid is in "switches and fitments"
