EFI OIL CHANGE
Posted: Thu May 28, 2015 10:57 am
by MartinB
I am in the middle of changing the oil on my EFI.I don't have a workshop manual but I seem to recall that as well as changing the oil and filter there is another filter on the underside of the crankcase which needs cleaning out?If I am right I assume it's the one that needs 2 8mm headed bolts screwing out to take off the cover plate and it's just a gauze filter that needs cleaning in petrol?
EFI OIL CHANGE
Posted: Thu May 28, 2015 1:00 pm
by Michael
Yup... and it serves as a second drain hole also.
EFI OIL CHANGE
Posted: Thu May 28, 2015 1:53 pm
by MartinB
Thank you Michael...all done now with no probs....have drained from both plugs.....
EFI OIL CHANGE
Posted: Thu May 28, 2015 2:06 pm
by Jack the Lad
Hi Martin
I hope you have also realised by now that the oil capacity stated in the manual is complete fiction. Mine takes about 2 litres to fill to the middle of the sight glass. Fill it to that level, run the engine for a couple of minutes to spread it around the gearbox, primary chaincase etc., leave it a minute or two to drain back and top it up again if you need to - it wont need much more. If you put the 2.7 litres in that manual says, it will blow out of the breather into the airbox - all over the air filter, then leak out over the back of the bike and the garage floor. Guess which idiot has been there and done that!
EFI OIL CHANGE
Posted: Thu May 28, 2015 4:07 pm
by MartinB
Martin/Jack the Lad-yes thanks I didn't bother measuring oil the oil-I just topped up to the sight glass,ran the engine and topped up some more.This is the third oil change I have done on this bike(I used to have an Electra X before)so I knew what to do except as I implied in my original post I have never used the other drain plug before but in future I shall undo both.
EFI OIL CHANGE
Posted: Thu May 28, 2015 4:38 pm
by Les
On the newer efi engines there is also a smaller drain plug towards the front he crank case, I put a 500g yoghurt pot under it thinking there would only be a small amount in that par of the engine filled it to overflowing
EFI OIL CHANGE
Posted: Thu May 28, 2015 8:11 pm
by MartinB
Mine's an early one and I didn't see anything else but thanks for the info which may help others.
EFI OIL CHANGE
Posted: Sat May 30, 2015 9:33 am
by ric
At last the secret of how to find the missing 0.7 litres has finally been revealed; unbelievable to think it was hiding inside the engine all along and not just a myth or workshop manual misprint.
EFI OIL CHANGE
Posted: Sat May 30, 2015 8:20 pm
by Les
From what I have read on the efi engines without the extra small drain plug a lot of leaning from side to side and shaking about gets some of it out
