- Fri May 22, 2015 7:35 pm
#5100
Hello again,
Just a quick post to check that I have inserted my new piston head correctly.
Looking at the engine from the timing side. (So front wheel to my right) When running, the crank shaft rotates in a clockwise direction.
Therefore, was I correct to assume the piston thrust face is toward the inlet side of barrel? Opposite to rotation.
It's not too late to rotate piston head if need be
Best regards.
Best regards.
