Gear slection problems
Posted: Sat May 16, 2015 11:10 am
Hi guys
New around here and also a complete newbie when it comes to bikes in general and Enfields in particular and I'm a bit stumped, even when working on cars transmissions have never been my strongest point
I've tried searching the net for a solution to my problem but I've come up blank
I have what I believe to be a 1999 Bullet 500, no idea if it's an export but I assume so. Sold new in Denmark (I think) and then later brought to Norway
My problem, aside from neutral being much easier to find than any gear but that's something I'll look into later, is that I can only get 1st through 3rd unless I reach down and lift the neutral lever with my hand and then it goes into 4th without moving the actual gear lever. Then the problem changes to only having 2nd through 4th and how I manage to get it back to "1-3 mode" is a bit of a mystery but it usually involves using the neutral finder and then several attempts at going for 1st .... which usually happens sooner or later but it makes driving in traffic less than enjoyable.
I've already ordered Pete Snidal's workshop manual but that's probably another week away from getting here and I'd like to get started on this problem
From what I've read elsewhere I gather these transmissions can have a bit of a "personality" and takes a bit of getting used to, and may not be assembled to the same level of accuracy one might expect from a more modern vehicle, but I'm quite okay with that but on this particular subject I'm totally blank
This bike has been sitting for a number of years and I've managed to get it running properly after cleaning up the carb and adjusting it properly but that only takes common sense, some logical thinking and being careful.
Any and all help will be most appreciated and please keep it simple, while I've got 35 years experience with cars I only have about 35 days worth of experience with bikes
