- Fri May 15, 2015 7:46 am
#47759
When I was only 20 I ran a Yamaha RD200 on Castrol R and the piston rings gummed up and the blow past pressure broke the piston up ..big misstake , R is only good for engines that are striped down after each race , nice smell but no good for road going bikes , my new 612 crank is very strong with a massive big end on needle rollers with a forged conrod , pretty hard to break and oil supply is supplied with the big bore pump and a UK spindle with a neoprene worm , super strong cam followers and all alloy push rods , Samrat rockers and full race valves and springs so the red line might be 6,000 rpm , speedway bikes use synthetic oil as it mixes with Methonal /Ethonal pretty well , with a forged Accralite piston getting the right timing is critical but with BP9ES plugs at 10:1 comp ratio I just dont know what colour they should be with the full Methonal conversion kit , I feel confident that I'm doing the right thing , I used to own a Honda/cosworth production racer CB77R that was very fast and this what gave me ideas about port shapes and this Enfield engine is the pinical of my knowledge . I intend to plod around most of the time and the bike itself is a standard 1995 export so not to get the cops on my back .
