legal for MOT
Posted: Sun May 20, 2012 10:05 pm
by Seadog
Dear all
I have a 1995 reg Indian export Bullet - which the previous owner had converted to single seat etc. I wish to further age it with further retro 1940's/50s style bits. What is the legal position if it no longer has indicators / stop light switch operated from front brake lever etc.?
thanks
legal for MOT
Posted: Sun May 20, 2012 10:21 pm
by John M
You need indicators unless the bike was first used before 1 August 1986, or is an 'off road' machine designed to carry only the rider.
Bikes used on or after 1/04/1986 need a brake light operated from both the front and rear brake.
That is unless you have no front or rear position lights fitted then you don't need any lights at all.
http://www.motuk.co.uk/manual/mc_contents.htm
legal for MOT
Posted: Mon May 21, 2012 12:54 am
Hello SEADOG ------JOHN M is quite correct with that info. However the regs. don't actually state that you must have two at the front and two at the rear. Have a look at PAUL GOFF ELECTRICS web site where you will find these handlebar-end lights. }------------BAR END INDICATORS
Easily fitted to any bike these indicators give much greater safety, particularly at night, without ruining the appearance £20.95 / pair . Particularly suitable for classics, these are reproductions of the Hella units fitted to 1960s BMWs and the Norton Electra. Pt.no. INDCB22/6 6V & INDCB22/12 12V
Indicator switch £8.95 Pt.no IND694997
Flasher unit £4.95 Pt.nos. 6V INDWRE05 12 V INDWRE06
2 x Bar End Indicators, 1 x flasher unit, 1 x handlebar switch + wiring diag. £35.20 Pt.no. INDBAR06V & INDBAR12V
NEW Now for 1.0" Pre Unit Triumph & Harley bars
Pt.nos. INDCB25/6 & INDCB25/12 and for kits INDBAR06V/25 AND INDBAR12V/25
Same prices as above ---------------------------- two of my friends have these fitted on 1965 BSA B40 WD bikes and until they are actually working you'd hardly notice them. Oh yes--- they have both been through several MoT tests ---so no probs with acceptance there. Hope that helps with the retro look ?
