- Mon May 04, 2015 7:04 am
#5025
Hi all. I could do with some help with some issues following removal of the headlight casquet. I replaced it with an alloy head stock which left me with the job of removing all the plastic multi way connectors by soldering and heat shrinking then into one loom all done. It also means that the ignition switch is removed. I was going to remove the key ignition and replace it with a simple switch where I didn't need a key. However by shorting the wire together that I thought were connected together in the original ignition switch I am not getting a spark. I could do with a wiring diagram or a second opinion of what wires are connected together at switch on. Depending on what configuration I connect the ignition wires I do get 12v at the coil but it gets very hot with no spark My bike is a 2009 350 trials. Any help appreciated. Cheers Nick
