Camshaft shims for a 612
Posted: Sat Apr 18, 2015 8:59 am
by Phil Ashbrook
Please could anybody tell me if it's OK to fit the shims on both side of the sports cams , is there enough room rather the outer side rubbing on alloy ? Plus the timing side woodrough key seems too big and has to be filed down a bit or it would foul the pinion .
Posted: Sat Apr 18, 2015 10:19 am
Phil, not sure why you would want to fit a shim on the inside, the cam runs up against the spindle, shim on the outside stops the cam running up against the timing cover
Posted: Sat Apr 18, 2015 11:21 am
by Bobw
Hi Phil, I,m not sure why the key would need filing. The timing side of the long stroke crank should be exactly the same as the original. Perhaps a light rub on a wet stone but the key needs to be a good fit in the slot and may need a gentle tap to seat it. Best not to start filing until you understand the problem.
Posted: Sat Apr 18, 2015 12:15 pm
by papasmurf
Woodruff keys are supposed to be a tightish fit. Deburr them carefully OK deburr the slot carefully OK, but beyond that No.
All you need to know about sizes and fits here. Just search it on Woodruff:-
http://cnqzu.com/library/Anarchy%20Fold ... 63_ym4.pdf
