- Tue Feb 14, 2012 10:57 pm
#9587
Chris you really need to do something about that before you ride the bike. It happened to me, just one nut was touching and it rubbed through the tank, then all of a sudden as I was riding along there was suddenly a large amount of vapour as petrol came gushing out of the tank, you have never seen anyone stop, get off a bike and leg it so fast! Luckily I had the presence of mind to switch the ignition off as I dismounted or there could have been really big problems. I was on a quiet country road so it was cope-with-able but imagine if that had happened in a busy city road!.
Either dremmel the nut as you suggest, or it can be replaced with a regular nut, not sure the thread but the ones that hold down the rocker bearing caps are just right. This does not cause an oil leak as it was exactly what I did once the tank had been repaired.
