- Thu Apr 02, 2015 7:29 pm
#4858
I have a 2004 bullet sixty-5 with an electrical problem. The bikes electrics will occasionally die, but only while idling or not running at all, never while running at speed. This seems to happen when the wiring harness is jiggled a bit and is usually mended by moving the harness around a bit more. I have peeled back the coating on the harness where the seat was rubbing against it, which I suspected had caused a wire to break but I can see no problem. I also have a fully charged battery, a working alternator and have double checked the grounding on the frame. Any thoughts on what might be wrong?
