- Sun Mar 22, 2015 9:28 pm
#4810
I need to remove the speedo drive from the front brake plate on the Model C I am restoring. There is a single cog inside the brake plate which is held on by a collar with what looks like a pin through the collar and shaft. Does any body know how to remove the pin from the collar such that I can remove it from the shaft and so remove the cog?
