Page 1 of 3
Expert opinions please (pic heavy)
Posted: Tue Mar 10, 2015 4:39 pm
by stefaand
Posted: Tue Mar 10, 2015 5:22 pm
Classic signs of piston blowby, probably caused by worn rings and bore. It also looks as if the oil hasn't been changed that regularly, and that's not unusual too!
Posted: Tue Mar 10, 2015 6:45 pm
by mauri
call the good man by his name, and he will come
all together now
father norm, father norm, …..
im no expert so will shut up, just passing for the pic’s.
Posted: Tue Mar 10, 2015 6:48 pm
by simon
Looks pretty good other than as already said its clearly time for new rings and a cleanup.
Posted: Tue Mar 10, 2015 6:53 pm
Mauri, not a lot more can be said Mark pretty much covered it
Posted: Tue Mar 10, 2015 7:49 pm
by stefaand
Thank you. It only has 22000 miles on it, I hope it's just the rings and perhaps a hone rather then a piston and bore..I'll make an appointment with the honda guru for measurement. And with the triumph guru for a magdyno pinion extractor, before i destroy the poor thing.
Posted: Tue Mar 10, 2015 8:06 pm
by stefaand
any tips on how to clean valves and piston? copper brush? toothbrush and petrol?
Posted: Tue Mar 10, 2015 8:11 pm
by papasmurf
Given the amount of cag on the piston, it needs throwing away not cleaning, unless you wish to measure the piston to see how much it is worn, and or how oval it is.
Posted: Tue Mar 10, 2015 8:15 pm
by stefaand
I wish to mind my budget, if anything
Posted: Tue Mar 10, 2015 8:32 pm
by papasmurf
Have you found any reason for the differential wear on the piston?
