Mr H's Trials kit rear light wiring
Posted: Sat Feb 28, 2015 1:23 pm
by Thunderchild
Dear all. I'm considering buying part 92515 and part 92518 but it's unclear whether the mudguard is drilled to accept the rear light and indicator wiring. Has anyone purchased these items and can let me know? I'd rather not have to drill the mudguard.
Thanks, Andy
Posted: Sat Feb 28, 2015 5:34 pm
by mauri
part 92518 is specifically drill’d for part 92518, there is no provision to guide the wiring.
there are no tabs inside like the steel mudguards.
mounted this rear light and had to re drill to adapt, and get the already drill holes welded shut.
i have used to lower arm of the rear loop to guide the wiring to the front.
you can alternatively buy a rear loop and a non drill’d mudguard to do as you please.
the non drill’d mudguard has to be cut down to length and shaped to clear the chain also.
