- Wed Feb 18, 2015 7:14 pm
#44481
Put on side stand (works on mine)
tie string on front wheel spoke, about 5 spokes up towards the front. then take around tyre to other side of wheel
feed string past sidestand to back wheel
Tie to lowish spoke at rear of rear wheel
adjust string so that it spans both wheels just above wheel rim height.
Sit in front of bike and carefully twist front wheel until string touches both front and back of tyre at widest point.
go to back and check string is touching both crossing points.
for double check, without moving front wheel or steering position , switch string to other side of bik, repeat as above.
I did try a laser pointer, but was too much hassle trying to hold and look at four points on two tyres at the same time without the thing moving.
REOC 15084
Tabellarius de verbis. Ostensor gaudium
