By steve a
#4677
does anyone have a good method of getting crude off of eleictical connections and wiring
By mauri
#44434
with crude, do you mean oxidation?
if its oxidation you can soda blast them, but that will only temporary solve the problem.
the anti oxidation coating is gone, the oxidation will come back.
replacing with new connections is the cheapest solution at that moment.
take in mind that when the wiring itself is oxidize, its not only the part you see its continues inside the pvc all along the wire.
#44436
Are you talking about the green "fur" which is copper sulphate?
This can be cleaned and neutralised with a rag dipped in a solution of washing soda.
A smear of Vaseline when dry helps to stop it reforming.
#44475
Bit of waxhoyl on a rag works and leaves a waterproof coating.
One of those little wire brushes with the dense brass wire bristles used for suede cleaning is pretty good. A.
