- Sun Feb 15, 2015 11:39 am
#4670
Hi all, I have recently bought a 2007 Electra X, which was running and started.
Unfortunately I now have no spark starter turns over fine, I have purchased a new battery as I suspected the old one was the original. But still no spark, side stand and clutch switches test ok. I've had the seat off and cleaned checked all connections, green tci unit fitted in 2012 (date written on it).
Starter turns over when I short across terminals, all fuses are ok. Neutral light is on and kill switch off.
One thing I did notice this morning was that when I pressed the started there was nothing - but if I rocked the kill switch the starter was intermittent so I suspect a faulty kill switch. ( ive taken it apart and cleaned/checked for any obvious problems but it all seems ok) question is would the kill switch allow the starter to turn but no spark to be supplied?
Any advice welcome, thank you.
