Model g forks
Posted: Sun Feb 08, 2015 7:15 pm
by SAboy
Hi guys i am hoping that one of you can help me with deciding what oil to use in my forks , apparently i am supposed to use SAE 20 but it seems that it is a bit elusive in new york , can anyone tell me if SAE 30 is good and also the amount of oil i should piut in the forks.
Thanks a bunch
Model g forks
Posted: Sun Feb 08, 2015 8:55 pm
by simon
30 will be fine however your generally want oil with an anti foaming additive in in for fork use. You should be able to purchase fork oil at any decent motorcycle shop or probably via post from our hosts. Harley's use 20 grade fork oil I believe so don't give up looking yet.
Model g forks
Posted: Sun Feb 08, 2015 9:46 pm
by SAboy
Thank you Simon , i guess i will keep hunting ,
Model g forks
Posted: Sun Feb 08, 2015 10:40 pm
by SAboy
I also see that most people say to add 200ml of oil in each fork , and also there are those who say , pour it in the top and let it run out the bottom , and replace the plugs when it stops running out, any ideas ?
Thanks
Model g forks
Posted: Mon Feb 09, 2015 1:24 am
by simon
If the Model G forks are the same or very similar to the Bullet forks then you take out the two screws located about three inches from the bottom rear of the fork stanchions and pour oil in the top until it begins to pour out from the holes.
Model g forks
Posted: Mon Feb 09, 2015 4:20 am
by Tim NZ
So called 'fork oil' is hellishly expensive for hydraulic oil.
#46 hydraulic oil is all that you need. Works find in wet clutch's too.
Model g forks
Posted: Mon Feb 09, 2015 2:33 pm
by SAboy
Thanks Simon , my forks have the oil fill at the top of the tubes and the drain plugs are on the bottom of the fork leg right where the stem comes out the bottom of the tube.
Model g forks
Posted: Tue Feb 10, 2015 2:07 am
by SAboy
Does anyone know the amount of oil to add , i would hate to do it incorrectely and mess something up, i have heard of really bad steering if its done wrong , also thanks again Simon I found a place that has straight SAE 20 fork oil , and i am picking it up this week.
Model g forks
Posted: Tue Feb 10, 2015 3:07 am
by simon
The level plugs set the levels. Buy 1/2 a Litre and top them up till it comes out the holes. That is the amount you put in. It's probably 180 to 200 mls but 500mls is more than enough for both legs.
Model g forks
Posted: Tue Feb 10, 2015 8:51 pm
by SAboy
Thanks Simon i will start with 200 ml and see where i end up
Thanks again
