Help identify missing part...
Posted: Sun May 13, 2012 8:24 pm
by MHSILVERW
My 2007/8 Iron 350 Bullet has the std 24mm(?)Mikarb fitted and what looks like an 'alloy' manifold with a pipe fitted to it; well it did until some help in clearing the garage seems to have resulted in this part being binned or lost....
I know some Bullets can have shorter suds and some tufnell spacer or such like but my bike with the longer studs that may be an issue.
Not being an expert and knowing how to change the studs safetly...
I wondered if anyone knew the part number for the 'alloy' manifold on the 350. Seems most straight fwd solution will be to replace it....but dont know the bit I need!
Regards
Mark
Posted: Sun May 13, 2012 9:57 pm
by m1ks
Did the alloy fitting have an air bleed screw?
Maybe one of the Indian market bullets? I know I've read that they had a manifold with an extra bleed screw.
I'm certainly no expert getting new to the bullet myself but I'm sure sometime can verify or otherwise.
I certainly don't recall seeing such a part in the hitchcocks book of goodies.
Posted: Sun May 13, 2012 10:32 pm
by Beezabryan
See "parts booka on line" the 350 Bullet Indian, then you can see this http://www.hitchcocksmotorcycles.com/pa ... arburettor it might just help. Click on the blue number s7 a oart description will show up
Posted: Sun May 13, 2012 10:35 pm
by Beezabryan
my fingers sure are fumbling this evening - Click on the blue number s7 a oart description will show up should be click on the blue numbers & a part description will show up. Time for bed surely so Good night all
Posted: Mon May 14, 2012 6:58 pm
by MHSILVERW
Hi,
It's not quite the same as that part which I think / gather were for home market bikes, after talking to our hosts and Watsonian Squire. The later models (mine is a 2007 registered in 2008) seem to have a 10mm or so (maybe a bit wider) alloy flange with a plastic pipe (now screw) sticking out; for when the bike was fitted to the PAV gubbins. Our hosts dont have one, and nor does Watsonian Squire. If anyone has a spare from one of the later 350 Bullets knocking about or anyone who maybe has changed to an amal or a different carb and would like to find a new home for their spare 'flange' than please, please drop me a line. Regards. Mark. [email protected]
Posted: Mon May 14, 2012 7:00 pm
by MHSILVERW
Bad typing, sorry...Hi, It's not quite the same as that part which I think / gather were for home market bikes, after talking to our hosts and Watsonian Squire. The later models (mine is a 2007 registered in 2008) seem to have a 10mm or so (maybe a bit wider) alloy flange with a plastic pipe (no screw) sticking out; for when the bike was fitted to the PAV gubbins. Our hosts dont have one, and nor does Watsonian Squire. If anyone has a spare from one of the later 350 Bullets knocking about or anyone who maybe has changed to an amal or a different carb and would like to find a new home for their spare 'flange' than please, please drop me a line. Regards. Mark. [email protected]
Posted: Mon May 14, 2012 8:27 pm
by grunda 12
hi there ,just get the shorter studs off a 90,s bullet and nuts ,lock 2 nuts on the long stud and undo ,the 10mm alloy spacer is unecessary,i changed mine to short studs and don,t worry you don,t need a mechanicing degree to do it pot a tuffnel spacer between carb & head or just a gasket no probs
Posted: Sat May 19, 2012 8:02 am
by Kristof
yes, take it out and put shorter studs. only the recent models of 350 made in India were fitted with that crap. with shorter studs it is also easy to reach the top screw of the carb if you wish to change the position of the needle.
Kristof
