- Fri Jan 16, 2015 6:46 am
#4590
I bet this is a first. I put the bike back together with the old oil pumps. I emailed our hosts asking if they were happy that I put hi capacity pumps in without a pressure release valve on the rocker feed and they haven't replied. I took that as a sign and reassembled the bike with everything back the way it was before the rather expensive experiment with the pumps. Anyway, stupidly I hadn't properly marked the arrangement of the alternator wires and in the process of fiddling with them I obviously managed to generate a spark in the primary case. All that was in there was ATF but clearly having been around the block it was warm and there must have been vapour in there because there was an almighty crump and the cover just started pissing ATF. There is nothing wrong with the alternator windings and it is now wired properly and charging nicely but the cover is cracked and bent out of shape. Who new ATF vapour would be so inflammable?
