- Thu Feb 16, 2012 9:07 pm
#9646
Hello Nige,
It's good advice what the other guys have replied to.
Carb, try moving the air mixture screw in 1/4" of a turn first.
screw in to make the mixture rich or out to make it weak.
Next ignition, with my 1959 250cc Clipper I set the ignition as follows. With the bike on the main stand a place a bit of plywood under the stand on the generator side only, this lets you turn the back wheel over by hand.
Then with the spark plug out & generator cover off I set the engine at T.D.C. on compression stroke.
Set the points to the right gap 14"/16" thou with the contact assembly in the middle of it's slots.
With some bluetack I stick a protractor onto the nut holding the rotor on.
You can slide a bit of white cardboard in behind the protractor & in front of field coils of the alternator, this will give you a chance to mark a reference point to line up with the protractor, slacken the two outer screws holding the contact plate to the casing then turn the back wheel by hand carefully anticlockwise till you see 5 degrees movement on the protractor, at this point move the contact plate clockwise till you just get the points to open on the cam, you can do this with a bit of paper in the points or on the ampmeter with the ignition switched on then nip the two outer screws up.
Sounds a lot to take in Nige but it's not that difficult, run throu it a couple of times till your happy then give it ago.
Handbook says 1/64" for the timing but try measurung that 5 degrees is equal to 1/64"
