- Thu Jan 01, 2015 6:24 am
#4543
Hi all. When I rebuilt the gearbox on my 1996 535cc, in my ignorance, I undid the one nut that shouldn’t be undone and moved the kickstart crescent from its position holding the pinion closed. Since I haven’t seen a picture showing where it should be, I’ve been guessing where it is correct – see the attached image (also in my photobucket account under ChrisD200).
But I guess I am still wrong because the kickstart lever moves ~30degrees from the vertical before biting on the high gear ks pinion (no, it is a new and undamaged pawl). This means the kickstarter cannot turn the engine far enough to get to the next TDC to fire.
Can anyone show me an image of exactly where the crescent must be fitted, or tell me how to set it up? – yes, I am aware I cannot adjust it too far before it wears itself away through ratcheting on the pinion inner teeth. Can anyone advise if the 30degree free travel of the ks is too much?
Thanks, ChrisD
Thanks, ChrisD
