Rear wheel adjusters
Posted: Fri Dec 12, 2014 1:44 pm
by Jim
I say chaps, could some kind person post a picture of our host's aftermarket rear wheel adjusters for the EFI please? I'm just wondering (given the difficulty in fitting them) if I ordered the wrong ones. at £27 a pair I can't afford to by another set just to find out. [/b][/b][/b] Ta
Posted: Fri Dec 12, 2014 6:22 pm
by Chris [Stockport]
Just had a look in the ACCESSORY SHOP (top left of Hitchcocks list)........ Then go to FRAME/CHASSIS.... and then to TYRES AND WHEELS. Found something there, with picture. Seems to fit a lot of models. Hope that helps. Sorry I can't put a picture on here myself. But maybe give that a try? Good luck, Chris
Posted: Fri Dec 12, 2014 11:34 pm
by Exile
Here you go..
Posted: Sat Dec 13, 2014 12:49 am
by Leon Novello
It is strange, most locknuts that I have encountered over many years, require a slimmer spanner than normal to hold the lower nut, causing great anquish as I had to grind down the face of the spanner to make it fit. Why is it so? One shouldn`t have to buy a special thin spanner which is usually hard to find in most stores anyway.
Posted: Sat Dec 13, 2014 1:28 am
Sometimes life is tough Leon
Posted: Sat Dec 13, 2014 2:53 am
by Mudplugger
Engage brain and put the thinner nut on top!!
Posted: Sat Dec 13, 2014 6:58 am
by Leon Novello
Hi Mud. The nuts are usually the same thickness and a lot of the machinery I worked on (or ) on which I worked, used an acorn nut for aesthetic purposes. I understand your concern for my sanity but it hasn`t been through as much strain as Norm`s and he seems to be managing.
Posted: Sat Dec 13, 2014 7:34 am
Leon, my life is moving forward now, I pulled down my last Bullet motor on Wednesday, it had broken a rod at 25,000ks, cases didn't look too bad from the outside, but the oil tank section inside was all smashed, cases went in the scrap bin and I told the owner to go and fit a diesel in it, so now I can look to a brighter future lol
Posted: Sat Dec 13, 2014 1:01 pm
by Jim
Gentlemen (and others) :-) Thanks for the raplies and thanks for the picture Lean. They seem to be the same as I have but they never seem to sit correctly at the back of the swinging arm. The catalogue gives a different part number for the EFI adjusters but no pictures.
Posted: Sat Dec 13, 2014 1:02 pm
by Jim
That should (of course) read "Thanks for the replies" and my apologies Leon for spelling your name wrong. we need an edit facility on these posts.
