By Katies Grandad
#4495
Is there a fitment for a 1959 250 Crusader. I have spoken to Boyer and they have a sensor plate to fit but are not sure if the rotor will fit without modification and suggested I contact you.
By Nettshubby
#42478
I would think they meant to ask Hitchcocks, rather than the forum, after all, they do sell the Boyer ignitions.
By Katies Grandad
#42479
They probably did but I can't find a contact link on the web site so I thought I'd try this. I also forgot to mention that it needs to be 12v positive earth.
By Leon F
#42487
Hi.
I used Boyer's inductive discharge ignition on my 1961 Crusader,. This works fine and is easy to fit. It saved all the hassle of fitting a full electronic ignition and does away with the unreliable condenser.
By Katies Grandad
#42491
Yes I was thinking of going down that route myself. I'm seeing a lot of arcing across the points and intermittent sparking at the plug so I suspect the condenser.
By Beezabryan
#42492
KG your capacitor is shagged & needs to be replaced at a lot less cost than going the electronic route
Leon F the "unreliable condenser" is usually either the New Old Stock or the unknown item that came with the basket case/ allegedly restored to original spec machine that is well past its sell by date, modern capacitors are good.
