- Thu Nov 27, 2014 11:36 am
#41989
There are two good practical methods.
The first is to put an ammeter across the fuse terminals, having removed the fuse first. Unfortunately, most electricians multimeters only handle up to 10 Amps, so this can be a problem unless you have a higher capacity meter or one of those ones that just clip very the wire and read it by electro magnetic field.
The other is to start with a low fuse value ( say 5 to 10Amps) and having taken the next few values upwards, start your bike. If the fuse blows with lights, brake light and engine running at speed, then you proceed to the next higher value fuse. When it seems that the current fuse value is not blowing then ride the bike somewhere so that you can run the engine at speed with load (not just rev the poor thing in on it's centre stand. (take fuses and tools needed just in case. Then physically check the fuse. If it is cold, then you should be opk with that value, however if it feels warm or hot, or shows signs that it is not happy, then change for the next value up.
Always carry a spare or two, plus one of a higher value to be used on an 'emergency get you home' only!
IF you have an electricians 10 Amp meter, then you can try the following. With all the lights OFF, run the engine at just over tickover until any residual battery charging is done, (ammeter reading slowly drops). Read the value that the bike settles down at. Make a note along the lines of 'Engine and system only' and putting the value from your meter. Next turn on the headlamp, which with a 50W bulb will use 4-5 amps, plus you will have the tigers eye and maybe a pilot in the headlamp shell, plus your speedo and ammeter (if fitted) backlighting. Check both high and low beam, for the higher value. Write down the value as 'lights on'. Turm lights off and try the brake light, again, note the value as 'brake'. You can try the same with the indicator, but due to their flashing, it makes reading a needle difficult, and most digital meters impossible, unless you have a 'hold peak value' button. The easiest way is to check the value of your indicator bulbs (21, or 10 Watt or LED) remeber to add the tell tale of about 2-3 Watts to twice the value of the bulbs (front and back, one side of course!)
TAke the values for 'lights on' and take the value of 'engine and system only' away from the value (otherwise on adding together, we would have the basic engine value twice!) add this new figure to the value 'Brake' and that should be pretty much accurate to the bike running with all lights and brake on. Now add on the value worked out for the indicators. That only leaves the indicator relay not accounted for, but by now, you should have a figure that can be rounded up to the next higher fuse value.
Again, try it out, check that the fuse and holder do not show signs of heating, and take spares with you.
REOC 15084
Tabellarius de verbis. Ostensor gaudium
