- Fri Nov 07, 2014 12:50 pm
#4366
Hi Folks, making good progress with my '59 Connie, did a VMCC run on her recently and all was well apart from a REALLY STIFF CLUTCH ACTION! She has a pushrod clutch and I'd already fitted 3 strong and 3 weak springs and a new cable, routed sensibly. The basket and plates are reasonably ok and it has the wider outboard spring plate which puts the springs in the right place for the friction areas. The pushrod assembly consists of a long rod with a hemispherical indentation one end plus the plain pressure pad (no ball fitted). The little ball inside the adjuster is free to rotate. I've read the tech note about the pushrod etc and plan to do the mod involving cutting the pushrod and adding balls, and have a couple of questions before I fire up the angle grinder: 1. Which end of the pushrod should the hemispherical indentation be (mine was fitted against the pressure pad where it didn't seem to do anything useful)? 2. The pushrod is a bit gnarled & worn and has waisted areas on the outer diameter, but it's fairly straight - is it ok or should I replace? 3. How many sections should I cut it into? 4. Is Mine Host's pushrod pressure pad with built in bearing worth trying? 5. Springs: 3+3 or 6 weak? Thanks in advance for any guidance. Stephen
Regards
Stephen
250 pre-unit Clipper
350 Indian Bullet Superstar
535 Bulsader
700 Conny
New 650 Interceptor
Stephen
535 Bulsader
700 Conny
New 650 Interceptor
