Drum brake problem
Posted: Tue Oct 28, 2014 7:38 pm
My front drum brake is causing a problem. Rotated forward it binds - rotate backwards it runs free. The details of the brake are:- newish brake linings (has worked well with these linings), fixed pivot single leading shoe. The brake plate is a rigid casting, there is no provision for adjusting pivot. Brake drum is clean and free of dust. I have taken great care to tighten everything to avoid distorting the brake plate. It sometimes work well but now having had to remove it this problem started. Have tried tightening anchor bolt whilst holding brake on hard. The anchor bolt is not connected to the brake pivot. Any ideas please ?
