Half Width Hub on QD
Posted: Sun Oct 19, 2014 8:00 am
by Count Johnny
Chaps
Further to my recent post, does anyone have any experience of retro-fitting a half width rear hub to an Indian Enfield Bullet (1996, in my case) using the QD spindle, etc and - if so - any hints, tips, tricks, pitfalls (apart from having rubbish brakes).
Thanks in advance.
Posted: Sun Oct 19, 2014 8:27 am
Johnny, no idea, but I would expect it to turn quite ugly because the original half width hubs had all sorts of spacers and distance pieces. Can be done but a lot of careful measuring will be needed
Posted: Sun Oct 19, 2014 10:09 am
by Count Johnny
Yes, Norm.
I've already worked out that I'd need to make a centre distance piece (basically the original spindle, chopped off where the bearings mount, with an O/D that fits snugly into the gap between the bearings in the hub, with a centre hole that allows the QD spindle to slide through.
Then, I'm guessing, I'd need to make a spacer to distance the inner race of the left hand bearing from the brake plate (but I'm just guessing).
Any other thoughts, chaps?
Posted: Sun Oct 19, 2014 10:14 am
by Count Johnny
Actually, thinking about it, I don't want the centre spacer to fit snugly to anything other than the inner races of the bearings, do I?
Posted: Sun Oct 19, 2014 10:58 am
by simon
Yep done it on the bitsa and it looks lovely. I made a new axle though rather than using the old one. The are a mountain of shagging around to set up and you can see why the QD was such a breakthrough but it does look smart especially with the lovely big cadmium plated nuts I made to tighten it all up. I can take a pic if you like?
Posted: Sun Oct 19, 2014 10:59 am
by simon
Oh just re read the question so clearly I didn't keep the QD axle :(
Posted: Sun Oct 19, 2014 11:17 am
by Count Johnny
A picture (or two) would be really helpful, if you don't mind Simon.
Posted: Sun Oct 19, 2014 11:20 am
by Count Johnny
Damn this lack of an edit feature
I should have said that I'm not fully sold on keeping the QD set up, so a picture (or two) would be really helpful, Simon.
Posted: Sun Oct 19, 2014 4:46 pm
The center spacer is exactly that a spacer to keep the inner races of the bearing in exactly the same position they are in now without side loading them when you tighten the axle up, after you have fitted the other 15 spacers
Posted: Mon Oct 20, 2014 2:40 am
by simon
I'll grab a pic or two this evening and post them. Yes Norm is right the important thing is to have no side loading on the bearings as they strip out the hub. the other spacers are to hold the brake plate away from the hub and on the other side to locate and secure the speedo drive.
S:)
