- Thu Oct 09, 2014 9:54 am
#4257
My bike has the alloy barrel conversion but I find after a run I get what looks like clean oil Between the fins and near the head joint. I don't think the head gasket has gone compression wise as she runs fine. Could the weep be coming through porous alloy as the oil looks cleaner than the engine oil as if filtered? Could the gasket let oil out without compression? It's not a big issue but it looks a bit messy so any ideas or common issues with the barrels? H
