- Sat Sep 27, 2014 7:43 am
#4207
I have nearly lost the will to live trying to find out how many and the EXACT location of the engine oil drain plugs on a Bullet Electra X.
Can anyone help please. Diagram or photo if possible.
Following the oil change instructions TO THE LETTER plus the how to check the oil level TO THE LETTER, (Instructions stapled to manual.) Putting the correct amount of oil in 2.25 litre resulted in a precisely 700cc over fill. Only found out after a 10 miles run on the machine.
It is VERY obvious that 700cc of oil never drained out.
I also have the large workshop manual on the subject which does not help.
(One good emergent property of the over fill, it made a loose connection and a split hose on the PAV system obvious.)
