By Ddraig
#4178
I am registering my UK enfield classic in Spain. I am changing the speedo from miles to Km but can anyone tell me is the headlamp direct beam or do I have to change that also?
Thanks
By Davie Hall
#39887
An easy way to check is start the bike and switch the lights on, and preferably when its turning dark point it at a wall about 2-3 metres away. On dip/low beam there will be a section of the beam going up to the left if it is a uk spec headlight if the beam does this it will need to be changed if it is flat along the top it will be ok for overseas use.
Hope this helps
