- Wed Sep 17, 2014 11:18 am
#4170
Can any of you give me some advice on a problem I have with my Enfield 500 bullet?
Its a 1992 early engine style 4 speed bike and the indicators are not working properly.
They originally tend to start flashing then stop after one or two flashes but on testing I found a more serious problem.
When the bike is not running with ignition on and a good battery the indicators are ok but with the engine running and the multimeter on the battery as soon as I turn the indicators on the battery voltage dropped from 13-14v to 5v so I quickly turned it off?
The old battery had clearly burnt out last year some time possibly due to this problem but the bike ran fine as do the lights. This does explain why the indicators would not flash as no battery power. With a new battery they flash ok as long as the engine aint running suggesting some conflicting wiring connections?
I have checked and shimmed the alternator which does have some historic rotor abrasion wear but when running its charging ok at 14V. The bike runs fine presumably without a good battery as the old one had about 5V left in it too.
I now don’t want to wreck the new battery of course.
Does this effect suggest reversed polarity or a direct short negative to positive? Why only when the engine is running? What changes in the wiring when the alternator kicks in?
So it seems the problem or a short is only happening when the indicators are switched on and only when the engine and alternator are running?
The indicators seem to have one wire to the bulb and the other to the bulb holder and stem earth I presume? Should the indicator stems not be earthed??
I found a load of poor earths above the carb which are now repaired but are there any known problem areas weak point to check out?
On cleaning these up the indicators wont work at all with ign on now suggesting one of the black wires may not be an earth at all???? Arrrrrrrrh!
I’ll undo them one by one but one cable runs outside the loom from the back of the headlamp suggesting its a non standard extra for something added by a past owner? So for now discount that issue.
Sadly very little on the bike appears standard and the wiring is a mess so I think I bought the problem with the bike as the indicators have never worked well. The Alternator is a two wire one not an Indian one possibly to run the Halogen headlamp bulb which is fine.
The ignition switch was mounted on the frame as no toolboxes were fitted but I’ve since moved it back into a toolbox I bought. Now so should the external barrel of the switch earth through the tool box to the frame? Toolbox paint may prevent this earthing well at present?
The handlebar switchgear does not look great or standard so I think I’ll check the wires there soon but if any of you have any pointers please let me know.
So in conclusion.
1. Ign on 12v battery - indicators working before I cleaned the earths?
2. Engine running indicators switched on battery Volts drop very quickly to 5V??
Would any of you have any parts I could trial fit to see if they cured the problem?
As the bike is post 86 I’m told I cant just remove and bin the indicators due to the MOT rules.
Thanks in advance.
Harvey
So in conclusion.
Thanks in advance.
Harvey
