- Fri Sep 12, 2014 8:41 pm
#4147
Bullet Loss of compression
Evening all
500 bullet Kickstart only, 2004, 8K miles
Went for 40 odd mile run yesterday, everything ok, plenty of power up hills & cruising at a true 50 to 55 at less than ¼ throttle.
Started it this afternoon, lots of compression. decompressed to get over TDC .
First kick started as normal. It ran for 30-60 seconds then stopped. Tried to start it again and found absolutely NO compression.
Kicking the engine over seems to be hissing at the carb on more than one stroke…..
Took the pushrod cover off, rods going up & down normally and spinning OK at TDC. Pulled the inlet rocker cover off & all looked OK.
Decompressor valve removed and checked, good seat all fine.
Then it got dark, will delve further tomorrow.
Anybody got any ideas what could cause a catastrophic loss of compression and what I may find on lifting the head???
Regards Fred.
Evening all
Regards Fred.
