- Mon Sep 08, 2014 10:56 am
#4134
Changed the bars on my Electra on Saturday, all going well, drilled the switch unit holes, everything fitting great - last job, tighten the clutch lever assembly mounting bolt. Just a tweak, maybe little more - CRACK! Yep, I stupidly cracked the aluminum casting - nightmare. After beating myself with a large club I logged on to our hosts site, to find they didn't have any in stock (arghhhh). Thinks....try my local dealer at Cambridge. After a few minutes rummaging they found they had 1 left in stock! cue mad dash to go and get it. Moral of this tale - the last bolt is as important as the first!!!!! And don't, ever, over tighten the clutch assembly..... By the way, raising the jet seems to have cured my previous hesitant high speed running issues as I had a great problem free ride out on Sunday.
If mine hosts read this you need to order some more clutch lever assemblies
