- Wed Sep 03, 2014 10:30 pm
#4121
I realise I'm probably the last person on the planet to realise this, but yesterday I found out how to remove the RH engine cover without draining the oil.
I discovered that by carefully laying the bike down on its left hand side, it would sit really nicely on its left footrest, with both wheels in contact with the ground. By turning the handlebars to the left it will lean over a bit more, but at no time does any other part of the bike get uncomfortably near the ground - not even my extended mirrors.
It is very stable, with no risk of it overbalancing and tipping right over. At that point it must be leaning a good 60 degrees, maybe more, which makes all the right side of the bike - especially the engine and exhaust, very easy to work on. Best of all, I found I could remove the right hand engine cover without losing any engine oil, as it is all sitting over on the left of the engine.
After finishing the job I gave the bike a fairly deep tip to the right to encourage the oil back to where it should be before starting.
This is the sort of thing that might not work on every Bullet - it all depends on the positioning of the footrests. Mine is a new B5 (UCE, EFi), so presumably bikes with a similar layout (and non-folding footrests, of course) would work.
Again, if I'm the last person alive to discover this, I apologise.
