Info Needed on 2 things
Posted: Sun Aug 31, 2014 11:25 pm
by grahamwalker
1/Well putting the steering head back in brought new 1/4 bearing the manual calls for 20 top and bottom but I seen to be able to fit 19 yes I have measured the balls 1/4", also do the dust covers on the ball races only just cover the joint mine are the orginals 1977 made of alloy.
2/ how hard is it to replace the rear mudguard I ask as mine has to have force applied to it to get in?
thanks for any help
Posted: Sun Aug 31, 2014 11:47 pm
by zippy
Hi Graham, Do you still have one of the old balls? If so measure it - You may well find it's smaller. I've had this on an old Soviet 2 wheel drive outfit, Turns out the head races took a smaller bearing than stated in the book for it's year (1972). when I removed It's etched and stamped makers plate from the headstock, It was stamped "ИрбиÌÑ‚ 1947 " into the frame underneath, Which is a tank factory,in the far east of the old soviet union - year 1947, They were factory reconditioning tired military outfits and exporting them as new civilian machines! I wouldn't put these sort of tactics above the Indians, Always check everything!
Posted: Mon Sep 01, 2014 4:41 pm
Graham, it's normal engineering practice with loose balls (Matron!) in a race to install one less than will actually fit to allow reasonable axial movement for the rest. If you check the Parts Books for Redditch models you will see this is the case, ie 19 balls specified for each race.
Posted: Mon Sep 01, 2014 9:44 pm
by grahamwalker
Right thanks all I fitted 19 in each race
